Code: P1453
Old Jan 24, 2012 | 04:19 PM
Jared9220's Avatar
Default Code: P1453
I'm leaving this forum and have deleted all my work in this thread.
Old Jan 24, 2012 | 07:50 PM
The evap system uses a small electric pump. The system tests the pump against and detects leaks as small as .02 inch by low pump current, and blockage by high current. In your case the pump current has exceed 40 milliamps, and this is one of the codes that can be cleared, then take four driving cycles to re-appear. Probably a bad DMTL pump (Diagnostic Module Tank Leakage). See attached.
File Type: pdf
File Type: pdf
Old Jan 25, 2012 | 03:11 PM
Not sure what is going on with your wire, but a coil with zip ties is not stock.
Heres one for a Rover, may have to call AB and ask them the variation for your truck.
Land Rover Fuel System Parts | Pump - Evaporative Loss Leak Detection - Diagnostic Module Tank Leakage System (DMTL)
Old Mar 1, 2014 | 11:17 AM
cza5150's Avatar
3rd Gear
Question So what happen with the P1453 Code??
Did u ever find out what cause the P1453?? What did you do to fix it??
Old Mar 1, 2014 | 06:25 PM
cza5150's Avatar
3rd Gear
Originally Posted by Jared9220
Wow this is a flashback. This has to be one of my very first post on here. Shame on me for not posting the fix.
Anyway, I had a bad leak detection pump. Here is the new part from AB: Pump Evap. Loss Leak Detection (Genuine Part # WTR000010) - Land Rover filler caps from Atlantic British
Thanks for posting the fix and part number! That will help me and others in this same situation!!
Old Mar 2, 2014 | 10:40 AM
jfall's Avatar
Smack me side the head - that bugger is expensive!!!
eBay time.
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
lebrult
Jan 24, 2012 12:41 PM
sayeedA
Nov 15, 2011 11:02 PM
