Code reader?
Old Aug 14, 2015 | 05:48 PM
mose802's Avatar
Default Code reader?
Will the ultra gauge read abs fault codes? If not can someone recommend an affordable scanner that will read everything for a discovery?
Old Aug 14, 2015 | 09:49 PM
cappedup's Avatar
No. UG won't do ABS codes. Most other things tho.
I use an Autel something or other for ABS.
UG is a great cheap tool for monitoring most of the day to day stuff.
Old Aug 14, 2015 | 11:20 PM
Charlie_V's Avatar
I thin think recommended combination is an Ultragauge and ABS Amigo.
Old Aug 15, 2015 | 08:23 AM
Bom2oo2's Avatar
Icarsoft i930 , is specialty tool for jaguar & land rover, will do most everything ,
But, won't reset computer, very good for the price, depends where you buy , it's around $130 to $150,
Old Aug 15, 2015 | 01:01 PM
drowssap's Avatar
X2 icarsoft great for the $
Old Aug 15, 2015 | 01:23 PM
chubbs878's Avatar
I'm happy with my new Bosch OBD1100 from Oreillys. It was about $80 and is supposed to read ABS codes but tells me that mine is undetected, which Im hoping is only because I don't have any ABS faults as I have no lights illuminated. This one shows live data too. If you step up to the 1150 or 1200 model you get like 10x times more options including a link that gives you repair and replacement options of the parts related to each fault code and Lyman's terms. Now that's what's up!
Old Aug 15, 2015 | 07:50 PM
bigred2929's Avatar
I have had good results with the autel al 619. Reads and clears disco three amigos. I think u have to update it though.
Old Aug 15, 2015 | 09:19 PM
mose802's Avatar
I guess I'll be purchasing a new code reader. Sine mine doesn't read abs. Dang 3 amigos on now!!!
Old Aug 16, 2015 | 10:47 AM
jfall's Avatar
Use http://enginecodemaster.com to type codes into it which may be hard to understand.
Patterned after the Rave manual
Old Sep 17, 2015 | 12:58 AM
moloha's Avatar
blue tooth ELM 327 dongle with Android app is the cheapest choice. I have mangoose pro with SDD software. It is good to enable cruise control and reset service interval.
blake989
Dec 6, 2007 11:44 AM
bookerbr
Feb 25, 2007 03:27 PM
KevC
Jan 20, 2007 08:21 PM
skins
Dec 29, 2006 03:56 PM
