Code throwing D2.
Old Dec 30, 2014 | 09:46 AM
WNYErikDiscoII's Avatar
Former Sponsor
Fuse # 2, 15amp in the engine bay. Check it out
Old Dec 30, 2014 | 11:09 AM
Dave03S's Avatar
On another note, it would be a very good idea to start checking your oil level more frequently than when it is due to be changed.
Which is good advice for any owner, not just the OP...
First thing in the morning, cold and on the level.
I have to top mine up a few times between oil changes. Which has been the case for me for the last 130k miles. And no, I don't ever see it dripping or leaking. So not seeing oil on the driveway is not an excuse to not check the level regularly between intervals.
Low levels do produce low oil pressure which will prematurely wear your engine bearings and camshaft. The light comes on at 7lbs. If you wait until then to add oil you've already done damage.
sayeedA
Nov 15, 2011 11:02 PM
2005bigbody
Dec 22, 2010 09:02 AM
bigake_t
Jan 15, 2008 09:16 PM
Kraftyz51
Oct 24, 2007 03:06 PM
MyRover01
Jan 4, 2007 09:53 PM
