codes 1313, 1314
Old Apr 16, 2007 | 01:13 PM
damon0809's Avatar
3rd Gear
Default codes 1313, 1314
Can anybody tell me what is the most common problem with these codes on a 98 disco series 1? Catalytic converter, O2 sensors, etc. Don't want to replace everything. And why won't check engine light reset when I unplug battery? It stays off for maybe a day or two after I reset it with the diagnostic machine, but never fails to illuminate itself once again.
Old Apr 16, 2007 | 01:20 PM
Default RE: codes 1313, 1314
Need some info on your truck, year, mileage, tune up history and what octane gas doe you use?
P1313 Misfire Catalyst Damage Fault Bank A
P1314 Misfire Catalyst Damage Fault Bank B
You have a couple of near damaged cats and need to find out why, get back to me.
Mike
Old Apr 16, 2007 | 01:31 PM
damon0809's Avatar
3rd Gear
1998 discovery 1, 109k, 87 octane. I alreadyreplaced the driver side catalytic converter because it was bad hoping that would fixthe problem. But the light still comes on. Also, I have an idle issue. I got it to idle better by unplugging the idle control valve, but I need it to work when it's plugged in, andthe problem is not the valve, because I've replaced that three times. Thanks
Old Apr 16, 2007 | 05:14 PM
87 octane will kill a Rover, carbons up the engine, and can cause valve damage.
You might want to send me your tele number and let walk thru what is going o,
Mike
mikeljacobs@comcast.net
csp
Jul 1, 2013 07:33 AM
klandrover
Jan 7, 2013 12:55 AM
Shawn Cross
Dec 21, 2012 07:17 PM
black sheep
May 2, 2012 06:58 PM
elboy0712
Mar 14, 2010 10:00 PM
