codes????
Old Feb 10, 2010 | 08:26 AM
XCELLER8's Avatar
FYI
P0171 " SYSTEM TOO LEAN BANK 1"
P0174 " SYSTEM TOO LEAN BANK 2"
Usually this would indicate a faulty MAF as stated above.....
P0733 "gear 3 incorrect ratio"
P0734 "gear 4 incorrect ratio"
it's highly unlikely that the gearing has magically changed....but more likely that the maf has caused your ecu to be a little goofy.....
do you have a code reader so you can clear these yourself ?
Old Feb 10, 2010 | 10:01 AM
chad420's Avatar
i do not have a code reader....I'm using just a fram air filter from murrays is that good enough....
Old Feb 10, 2010 | 10:06 AM
okdiscoguy's Avatar
yea, that is good enough. As long as it is a regular paper filter. The K&N will kill your MAF.
Old Feb 10, 2010 | 12:01 PM
chad420's Avatar
what about using an amsoil air filter or mann air filter??? anyone have any thoughts
Old Feb 10, 2010 | 12:03 PM
chad420's Avatar
who has the best MAF to buy??? I usually buy from AB??
Old Feb 10, 2010 | 12:24 PM
lipadj46's Avatar
Just buy a regular old paper filter whether it be a fram, napa gold, mann or OEM. Get a genuine rover MAF. Check with will tillery.
Old Feb 10, 2010 | 12:35 PM
okdiscoguy's Avatar
Do not use any high flow filter that you have to oil. The oil can come off the filter and will instantly kill the MAF on a D2, as will trying to clean it.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
