Codes
Old Oct 27, 2007 | 07:22 PM
Camdisco24's Avatar
Default Codes
Ok check engine light is on and here are some codes that I got, my guess is O2 sensors but I will leave it up to you guys. Here they are:
P1175
Manfac. Contrl.
Fuel Air Metering
P1172
Manfac. Contrl.
Fuel Air Metering
P0455
EVAP Emission Control System Leak (Large)
Old Oct 27, 2007 | 08:26 PM
okdiscoguy's Avatar
Default RE: Codes
If you have not changed them yet, it is getting to be time anyway. Also, have you checked your gas cap?(P0455)
Old Oct 27, 2007 | 10:07 PM
Camdisco24's Avatar
Default RE: Codes
Yeah, I get that code everytime. And I always check the gas cap so I dont think thats it. Is there anything else it could be?
Old Oct 27, 2007 | 10:38 PM
okdiscoguy's Avatar
Default RE: Codes
crack in your gas tank, vacuum lines , or fittings...Not too sure.
Old Oct 28, 2007 | 09:06 AM
Default RE: Codes
First, the 1172 code is incorrect, it should read, P1172 Oxygen Sensor System Too Rich Fault Banks A & B
As for the evap leak, as already mentioned, could be a cracked evap line, maybe a really bad gas cap.
Yes, you are ready for 02 sensors, by mileage, but they are not causing this problem.
Need more information, what has been done lately from a tune up stand point, what octane gas do you run?
Old Oct 28, 2007 | 11:37 AM
Camdisco24's Avatar
Default RE: Codes
I always run premium, 93 Octane. I got the codes from Advance auto zone. I guess I am going to have to bring it somewhere else to get Land Rover codes because Advance said only the manufacturer would know the first two codes.
Old Oct 28, 2007 | 12:12 PM
okdiscoguy's Avatar
Default RE: Codes
www.iequus.com is the best I have found for codes. Most manufacturers are listed....
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
