Codes From ABS Amigo
Old Nov 7, 2010 | 11:36 PM
hilltoppersx's Avatar
scan your truck again.
i have to get mine tomorrow and pull it to make sure. i know it stores every scan it has completed in the .txt file, but i think they are numbered seperatly which i don't see on your txt.
am i correct in saying you only plugged the amigo in once?
Old Nov 8, 2010 | 02:09 PM
FightOnUSC79's Avatar
correct, I only scanned it the one time.
Old Nov 8, 2010 | 06:15 PM
previous faults is a previous scan. If this is your Amigo and this is the third time you scanned your truck than yes listen to Mike. If you bought this Amigo used OR are borrowing it from someone, AND this is the first time you scanned your truck then that fault is not yours. I'm trying to make sure that the repair you are going to undertake is actually for your truck. The way the Amigo works is it saves every scan that is had done. Your amigo shows it has scanned three times and found a fault only on the second scan. Hope this helps you understand how it works.
here is the new scan:
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Looks the same. Also, I am using this on a Mac with Office software. WOuld this be making the outcome look any different, as i know the interactions say us eon windows based PC
Old Nov 8, 2010 | 07:40 PM
no being on the Mac won't change it. If i were you i would wait for them to come back on, then scan it again and see if you get the 022 error again.
Old Nov 9, 2010 | 09:11 PM
Will do, they have only come on once so now it's just a waiting game. Nifty device I have if I don't ever need it! maybe I can rent it out until I do
Old Nov 10, 2010 | 06:25 AM
yes you can rent it out and reclaim a few bucks here and there. I rent mine out to club members and I think Josh at USVI land rover club rents his out on his site.
one more question, does your HDC work properly? is you ABS system working properly?
lipadj46
Apr 13, 2017 04:51 PM
yuenie
Jan 13, 2010 05:37 PM
Princess
Jul 4, 2009 12:24 PM
Malafax_Dand
Mar 30, 2009 06:31 PM
