codes galore after 02 replacement
Old Oct 19, 2016 | 09:17 PM
robersonb's Avatar
Default codes galore after 02 replacement
Had couple codes indicating 02 sensors. went ahead and had all 4 changed out. Had to do it in two goes however. After they replaced 1 sensor, my codes disappeared except for one pending code. They finished putting the other 3 in today. On the way home, my ultra guage lit up and shows 0135, 0155, 011, 0161. Any ideas what has happened? This is after we just finished a head gasket, new wires, plugs, cam, whole nine yards. Also replaced MAF earlier. What could have happened?
Old Oct 20, 2016 | 06:26 AM
dgi 07's Avatar
Either you have a wiring problem or your O2 were bad out of the box.
Old Oct 20, 2016 | 06:58 AM
chubbs878's Avatar
you should also be using factory, genuine Bosch replacement parts. The Bosch system struggles with cheap, aftermarket sensors like those for oxyen, mass air flow, cam position, etc. The Bosch parts are about twice the cost of aftermarket, but there are too many testimonials of cheap parts causing abundant fault codes and just making problems much worse.
Old Oct 20, 2016 | 11:27 AM
jamieb's Avatar
Assuming you used Bosch and put the front sensors up front and the rear sensors in the rear, it took a while for my ECU to cycle and clear the light and codes. In other words, the results are not instant. The computer needs time and mileage to reset with the new sensors. As far as new codes, yes, you want to check for defects or issues. The old codes are what I am referring to.
Old Oct 20, 2016 | 10:24 PM
robersonb's Avatar
Well, I don't think they were Bosch so that is probably my problem. However, if the mechanic put 2 in the wrong places would that do it? Because the fronts are different from the back are they not? considering after he replaced 1 and I was down to only 1 pending code, I'm thinking I only had one more bad 02 sensor. These codes didn't come until the last 3 were put on.
Polo//S4
Dec 5, 2012 05:27 PM
StormTroopa
May 17, 2011 08:37 AM
kingsly
Dec 27, 2009 12:25 PM
skatelove303
Oct 31, 2009 08:26 PM
ajh
Aug 22, 2007 05:30 PM
