Codes: P0150 P0174 P1174 + pending
Old Jan 14, 2013 | 12:14 PM
Antmen's Avatar
Default Codes: P0150 P0174 P1174 + pending
I'm at 120K now (see sig for all that's been done) and about a week ago i started smelling a somewhat "burnt" smell in the exhaust. A couple days later, I got codes:
  • P0150
  • P0174
  • P1164
and pending code:
  • P0159
I noticed this morning that while warming up, the exhaust white smoke was more than usual. It's gone once up to normal operating temp. But while warming up, it's a lot more than the usual cold start morning. Plus, as mentioned before, the exhaust smells "funny." If I had to explain it, it smells like burnt plastic or something similar. The idle is slightly rough. I'm guessing it's burning rich, but not sure.
I had the upstream O2's replaced when I first got the truck at, I think, around 87-90K.
-Anthony
Old Jan 14, 2013 | 12:56 PM
150, bank 2 sensor 1 malfunction
174 bank 2 running lean, cause 150 code
159, bank 2 sensor 2, slow to respond
can't find the 1164 but it is safe it is similiar to the 174 code.
I would say both bank 2 02's need replacing.
Old Jan 14, 2013 | 01:02 PM
Antmen's Avatar
Will order both O2's on Amazon (Bosch OE) - will be here on Tuesday. Will replace, reset, and update. In the meantime, she's parked in the lot and will only fetch the kids after school - I'd hate to foul the plugs.
Thanks, Mike!
-Anthony
Old Jan 15, 2013 | 01:05 AM
jfall's Avatar
Has the coolant level gone down?
Hopefully you will not get misfire codes soon.
Old Jan 16, 2013 | 03:53 PM
Antmen's Avatar
No. No coolant loss. The only loss I had was right after a flush, the bleeder screw started leaking so I replaced it. But no coolant loss, no sweet smell in the exhaust, and no prolonged white smoke (other than before it warms up.)
'Got the O2's today and will replace, reset, and then see if the codes come back or not.
-Anthony
jallen9
May 8, 2013 12:24 AM
baburhan
Sep 20, 2010 02:42 PM
richief556
Aug 5, 2010 09:08 AM
787tech
Jul 9, 2008 02:43 AM
hriant88
Apr 30, 2008 07:33 AM
