Coil Pack Firing Order Diagram
Old Apr 6, 2017 | 09:42 AM
twin6's Avatar
Default Coil Pack Firing Order Diagram
I thought I would add this little visual aid. I know I could have used it.
Old Apr 6, 2017 | 10:35 AM
mollusc's Avatar
It's not clear on that diagram which is the top and which is the bottom row of the coil packs.
There are tons of threads on here that include diagrams.
Old Apr 6, 2017 | 10:56 AM
OverRover's Avatar
The 1st pic is the same idea, only the view would be if you are STANDING IN FRONT OF THE TRUCK. The 2nd pic, viewed from the back (like the OP's pic).
Old Apr 6, 2017 | 11:17 AM
LRD2rangel's Avatar
I'll just leave this here
Old Apr 6, 2017 | 02:05 PM
twin6's Avatar
Perfectly clear to me since I labeled driver and passenger sides of the coil packs there is only one orientation that makes since for US drivers and that would be from the position of looking from the driver seat out towards engine. I kept that same perspective whhen I drew the engine. The one from LRD2 I find confusing since the numbers for the coil pack top and bottom are reversed geometrically. It is not until I read that the top is on the bottom and the bottom is on the top that I get it.
Anyway it is intended to help...
Old Apr 7, 2017 | 06:35 AM
mollusc's Avatar
If I'm standing in front of the truck -- as one tends to be when one is changing the coil packs -- then a view from the driver's seat requires some mental inversion.
I used the diagrams provided by LRD2 when I did mine because they're explicit about every aspect. While it might look like the coil packs are inverted, that's how they are orientated when they're lying on top of the lower intake when you're about to install them.
"Driver" and "passenger" also aren't necessarily explicit since these trucks come in both LHD and RHD, and this is an international site.
I wasn't meaning to offend; I just didn't find them to be any clearer than the several other versions that I had already seen, and there was room for interpretive error.
Old Apr 7, 2017 | 08:23 AM
twin6's Avatar
Hey listen... The best thing about this forum is the accuracy and promptness of replies that help guys like me get and keep their Rovers on the road. I am not offended at all. Passion around getting correct information out in this forum is important. We can all agree about that.
bardel
Jul 28, 2010 10:50 PM
gregstil7
Jan 16, 2010 04:16 PM
mx930
Dec 30, 2008 08:08 PM
JEFIII
Apr 23, 2008 11:10 AM
bboat567
Jan 15, 2006 11:15 PM
