Coil Pack Relocation Project
Old Feb 3, 2017 | 10:13 AM
  #31
LR03NJ's Avatar
Originally Posted by dgi 07
Are you are machinst, or have open access to a machine shop?
I design professional mounting and equipment brackets. I access an in-house company machine shop. I can often do some personal stuff i need depending if they are busy or not. But often, they let me.
Old Feb 3, 2017 | 10:56 AM
  #32
shanechevelle's Avatar
Originally Posted by chubbs878
Next you are going to post pictures of extending/rerouting the electrical connections for the coil packs? This is a detailed, professional-looking modification. I would probably replicate this if it wasn't for my constantly having to repair or replace something. I can't even go pick up my upgraded driveshafts and switch the rear pinion to a U-joint type because something breaks down just about every day. Fresh top-end on a solid (for now) engine that I can't run because of all these junky parts. I haven't decided if I'm going to crush my truck or get it sold to my worst enemy.
I'll take it...how much
Old Feb 4, 2017 | 01:44 AM
  #33
DailyDrivenTJ's Avatar
Originally Posted by LR03NJ
As for the moment, waiting for the last connector to make a harness. I'll update
Can't wait to see this!
Old Feb 4, 2017 | 05:40 AM
  #34
number9's Avatar
You found the connectors needed for an extension harness?
Your relocation project looks great.
Old Feb 4, 2017 | 07:48 AM
  #35
Luckyjayb's Avatar
You still got it looking great man. Ready to see the finished outcome. Might have to get you to make me that custom bracket set up so I can do the same. I was thinking, you might be able to get a elbow and use on of the intake bolts to use as a wire router over that and keep it away from the alternator.
Old Feb 4, 2017 | 07:55 AM
  #36
LR03NJ's Avatar
Thanks,
Got the wire properly routed towards the other side. The wire clips originally installed at the back of the engine, 2 of them was reused. The wires crossing the alternator is not touching it. The bolt that holds the plastic cover right next to the alternator will be used to secure the other clip. It looks straight across the engine now and its looking neat. Im almost there, the last clips tracking just arrived somewhere in US. Cheers
Old Feb 4, 2017 | 07:58 AM
  #37
Luckyjayb's Avatar
Thanks,
good deal. When you get it done, you might have a side job making life easier for us!!!!
Old Feb 4, 2017 | 07:59 AM
  #38
LR03NJ's Avatar
Thank you. I'm almost there at the final stages. Im not sure if I can reach the connectors from the back of the engine but I have to just to make sure I'll be able to trace the right wires to extend it. Thanks again
Old Feb 4, 2017 | 08:01 AM
  #39
Luckyjayb's Avatar
i got big hand and can reach them barely behind mind but I'm thinking since you have the coild packs disconnected, you should be able to get to them easy enough if you are lucky enough to have em wired the first time. Got my fingers crossed for ya
Old Feb 4, 2017 | 08:02 AM
  #40
LR03NJ's Avatar
The last clip for harness just arrived in US so its just few days to make it happen. Almost there. Wires are all measured up already and extended to all points of connection. Plug and play. I'm hoping.
