Coil Pack replacement question...
Old May 3, 2017 | 11:14 AM
mollusc's Avatar
P1319 seems to be possibly related to low fuel pressure if your tank is near empty, although that may not be a definitive cause. Some deeper digging indicates that another cause for that code is clogged catalytic converters resulting in high backpressure; if you've been misfiring for a while then it makes sense that your cats might be toast.
But start with plugs, wires, and coil packs. Based on some of the cleared codes it looks like you might need to do your downstream O2 sensors as well.
Old May 3, 2017 | 01:28 PM
Dave03S's Avatar
Got to think about what would toast your cats and cause misfires. Time for a block check to see if there may be coolant in one of the cylinders.
Old May 3, 2017 | 02:17 PM
mollusc's Avatar
Bad plugs, wires, coils, O2s, MAF, purge valve, and many other things can all cause misfires. Checking for head gasket leaks or block cracks is not a bad idea, but things might not be that bad.
Old May 3, 2017 | 08:20 PM
Alex_M's Avatar
Don't quote me on this, but I seem to remember a number of those codes being associated with bad MAF sensors, specifically the "wrong ratio" code. That in conjunction with bad O2 sensors would definitely cause misfires. Definitely do some searching, but if I'm remembering correctly then that may set you in the right direction.
Old May 8, 2017 | 12:20 PM
cobbcj7's Avatar
I bought a cheap Ebay MAF about a year ago, and just cleaned it last week and maybe that is my problem...
I can literally drive the truck 10miles to work without the CE light flashing... And sometimes when I start it, the CE flashing happens right away... Actually it is happening more than not, that the CE light flashes on start up, but goes away and won't start flashing unless I apply too much throttle, or when climbing a hill.. once I let off, it stops flashing and won't start again unless I climb a hill again...
Old May 8, 2017 | 12:44 PM
mln01's Avatar
Disco Mike was always adamant that we should buy only genuine Bosch MAFs. He'd seen too many instances of aftermarket MAFs failing out of the box.
Old May 8, 2017 | 04:52 PM
Best4x4's Avatar
I grab OEM ones from the junk yard all the time. Sensor itself is the same on 99-02 Range Rover's, 99-02 D2, and 03-04 D2's. Only difference is the housing itself (4.0 vs 4.6). I normally get them anywhere from 5.00 to 15.00 tops. Never hurts to have a few trail spares.
Old May 19, 2017 | 11:05 AM
cobbcj7's Avatar
Default Maf
It's the MAF apparently..
Old May 19, 2017 | 12:04 PM
KingKoopa's Avatar
VW beetles use the same MAF as well. I found several in town because the Beetle is way more common than the disco. They were all trashed due to sitting out in the weather but they were all the same Bosch model number as the disco unit, so viable option if your area doesn't have a bunch of discos
Old Jun 29, 2017 | 08:00 PM
cobbcj7's Avatar
Thumbs up I got it done
Ok, so I got motivated and decided to tackle the job... I was able to change out he coil packs and plugs without removing the intake. Getting the coild packs out was very tight but it's doable! My hands are beat to hell, my ribs hurt from laying on the engine, and I can't find that wrench I threw as far as I could...
Truck runs great! no codes!
Glad it's done!!
tmckenz
Mar 19, 2015 06:28 AM
detroitmike
Jul 22, 2014 09:46 AM
discobob
Jun 10, 2014 06:38 PM
Ad!
Mar 21, 2012 06:57 AM
sparky
Jul 7, 2009 02:54 PM
