Coil Pack Replacement Suggestions
Old May 27, 2014 | 09:20 AM
detroitmike's Avatar
Default Update
Well, I purchase and installed the Standard brand coil pack, and my Disco is running like a dream. Less than $70.00 including shipping, and I've noticed an increase in performance since even before I started getting these problems. Oddly enough, the Three Amigos haven't returned either since I've completed the work.
Old Jul 10, 2014 | 07:40 PM
rchrd0413's Avatar
Would you post a link to where you purchased them please?
Old Jul 13, 2014 | 07:22 AM
I ordered the pack through JC Whitney. There were other sites that had it, but I'd never dealt with them before so chose Whitney based on the fact that they've been around a long while.
The part number or the coil pack is SIUF545. A google search for that part number will return multiple results for all the sites selling it.
Old Jul 14, 2014 | 07:56 AM
rchrd0413's Avatar
Thank you
Old Jul 21, 2014 | 10:31 PM
krammark's Avatar
Rave manual instructions for removing upper intake manifold (UIM) say to undo all the coil pack bolts before removing UIM. On reassembly the UIM is torqued down before putting the coil pack back in place.
My question is why remove the UIM in the first place? Can the coil pack be removed after the UIM is removed and then replace the coil pack before bolting down the UIM?
Why loosen the coil pack before the UIM comes off? Is the coil pack bracket holding down the UIM?
Old Jul 22, 2014 | 09:37 AM
Thank you
you're very welcome!
Old Jul 22, 2014 | 09:41 AM
If I recall correctly, I removed the UIM prior to removing any bolts for the coil pack, or coil pack bracket. I don't have my Rave manual handy at the moment, I'll try to look at it again tonight to see if I might be forgetting a step. My guess is that at best, there's two bolts that may be attached to the UIM that will need to be removed first, but again, I don't recall that being the case.
Old Jul 22, 2014 | 09:46 AM
drowssap's Avatar
pm sent
tmckenz
Mar 19, 2015 06:28 AM
cammyr01
Jan 1, 2015 10:13 AM
discobob
Jun 10, 2014 06:38 PM
Ad!
Mar 21, 2012 06:57 AM
sparky
Jul 7, 2009 02:54 PM
