Coin drawer and ashtray stuck
Old Nov 17, 2017 | 07:07 AM
dcaven's Avatar
Default Coin drawer and ashtray stuck
Both of these are stuck in the open position. Aparently something is blocking them from behind. I can't see anything and Rave says nothing about this issue. I would like to get them working as I plan on installing some toggle switches on the coin tray. I will need to add something that helps it latch securely but not permenantly. Suggestions? Thanks.
Old Nov 17, 2017 | 07:59 AM
Kdo58's Avatar
The fix is using a zip tie, you will have to do a search.
Old Nov 17, 2017 | 08:17 AM
dcaven's Avatar
Default No luck
No luck searching either coin drawer nor zip tie.
Old Nov 17, 2017 | 08:38 AM
Kdo58's Avatar
https://landroverforums.com/forum/di...de-pics-43588/
Old Nov 17, 2017 | 10:31 AM
dcaven's Avatar
Default Looks helpful once i get it out
I got the ashtray in the dash. It doesn't work but at least it isn't out. The coin drawer won't move in or out. I need to know how to get behind it and remove it from the back.
Old Nov 17, 2017 | 03:45 PM
emncfi's Avatar
The screws to remove that lower portion are behind the ashtray and coin drawer, there are 3 per side
Sixpack577
Jul 23, 2017 02:09 PM
Discochick
Nov 15, 2014 07:52 PM
cosmiccharlie
Apr 18, 2013 08:29 PM
aguison
Sep 25, 2012 07:10 AM
