Cold weather - heater = no bueno
Old Dec 23, 2019 | 10:24 PM
kylltyme1's Avatar
8th Gear
Default Cold weather - heater = no bueno
Hi All,
So my heater died the other day, just as it started to snow (of course). I have no idea what it is and I looked here on the forum to see if anyone had the same issues but I couldn’t find anything. I do apologize if this is a redundant post!
Anyhow, my heater motor works as it’s blowing air but the heat is non existent. The AC works beautifully but that’s not what I need. What are your thoughts??
Thank you from my igloo.
Old Dec 23, 2019 | 11:27 PM
greisinb's Avatar
Barring anything wrong with the actual coolant/heater core there is a servo activated flap that mixes cool air and heater air in whatever proportion is needed to get the temperature you want. If the servo failed in such a position that the flap is blocking air flow to the heater core that would explain why the AC works but no heat.
Old Dec 25, 2019 | 10:57 AM
kylltyme1's Avatar
8th Gear
Thanks for the heads up! I’ll take a look at it. It seems fairly easy to pull out the assembly.
ccriderbmg
May 21, 2019 12:05 AM
LR03NJ
Oct 19, 2017 06:04 PM
redrover75
Dec 3, 2016 10:00 AM
sorusty
Dec 5, 2011 03:29 PM
01d2Jeff
Oct 25, 2011 09:35 AM
