Combining Front Mids And Woofer On Disco II
No luck so far with this in the electronics section, thought I'd try here...![Cool](https://landroverforums.com/forum/images/smilies/kKt1IJ6.png)
https://landroverforums.com/forum/au...isco-ii-59336/
I saw your other post but didn't get a chance to respond. The system is set up with the cross overs in the amp, and the lows are sent to the woofers on one feed and the mids and tweeters are fed off another set of wires. You might be better off running the woofer signals to the 6.5's to pick up the lower frequencies, but if it sounds good you may not want to waste your time.
ProRiderRoadKing
Audio/Visual Electronics
07-11-2013 04:18 AM
MountDisco
08-13-2010 11:29 PM
Captain Ducman
06-05-2007 02:08 PM
