Combining Front Mids And Woofer On Disco II
Old May 25, 2013 | 10:31 PM
ProRiderRoadKing's Avatar
Default Combining Front Mids And Woofer On Disco II
No luck so far with this in the electronics section, thought I'd try here...
https://landroverforums.com/forum/au...isco-ii-59336/
Old May 26, 2013 | 09:11 AM
Copper99's Avatar
6th Gear
I would try the woofer connetion an see how the set sounds. I would assume that the amp is high pass filtered at around 70-80hz rather than band passed.
As for combining the two...........i dont see how that could be done.
Old May 26, 2013 | 09:19 AM
04duxlr's Avatar
I saw your other post but didn't get a chance to respond. The system is set up with the cross overs in the amp, and the lows are sent to the woofers on one feed and the mids and tweeters are fed off another set of wires. You might be better off running the woofer signals to the 6.5's to pick up the lower frequencies, but if it sounds good you may not want to waste your time.
Old May 26, 2013 | 11:15 AM
Cool, thanks guys, I'll leave it be for now. I wasn't looking forward to messing with the door cards again anyway haha
ProRiderRoadKing
Audio/Visual Electronics
Jul 11, 2013 04:18 AM
WaltNYC
Sep 26, 2011 10:35 AM
MountDisco
Aug 13, 2010 11:29 PM
thebiglad
Mar 14, 2008 09:15 AM
Captain Ducman
Jun 5, 2007 02:08 PM
