Is it common for the main underhood fuse box to fail?
Having an issue with battery draining over night. I've traced it to main fuse box under hood. With every fuse and relay out of it it still pulls a load, only way no current is drawn is if fuse box is totally disconnected as in battery lead is disconnected from fuse box
Charlie, disconnect the negative battery cable, and use a multimeter set to millaamp to bridge between the negative battery terminal and now disconnected battery cable. Close all doors, tape down the hood ajar switch, and wait about 30 minutes for the ECU to go to sleep. If you have a serious drain, the meter will read several amps. Begin pulling fuses one at a time and find which fuse drops the readings on the meter. If you have to open the driver's door to pull fuses from the passenger compartment, note how many amps the meter raised when the dome light turned on, and keep that in mind.
A vehicle without any problems will have about a 0.1 amp drain from the clock, radio etc.
Don't open the door. Leave it open and close the latch. Seen to many blown out meters because someone opened a door. Rest of the explanation, I will co-sign on.
OP, stranger things have happened....
Last edited by dgi 07; Aug 27, 2015 at 10:18 PM. Reason: Additions and spelling changes
Blakesrover
Feb 21, 2013 01:43 AM
DiscoIIBrandon
May 20, 2011 04:55 AM
DiscoIIBrandon
May 12, 2011 09:59 AM
