Compression test numbers...
I recently picked up a 03 disco that "needed a new engine." I was not bothered by the engine because I have a diesel that I'm going to be stepping in at some point. I figured I would at least see what is wrong with this 4.6 since I'm still saving up for the diesel swap. Anyways, all I was told was that the rover had overheated. I did a dry and dry test today on the engine and have super low numbers. Here's the results
Dry. Wet
1: 155 1: 200
2: 170. 2: 200
3: 100. 3.110
4: 110. 4: 120
5: 70. 5: 70
6: 65. 6: 70
7:80. 7: 70
8: 85. 8: 90
Any ideas? I was hoping maybe I could do head gaskets and call it but I don't think that's the case after seeing this. Thanks for any info! Cody
Dry. Wet
1: 155 1: 200
2: 170. 2: 200
3: 100. 3.110
4: 110. 4: 120
5: 70. 5: 70
6: 65. 6: 70
7:80. 7: 70
8: 85. 8: 90
An HG job would include a trip to machine shop, where a valve job is normally part of the price. $250 in my case. $118 for HG kit. With bad HGs, and warped heads, adding oil won't make much difference as gasket is not holding pressure to start with.
On the other hand, if you pull the heads, you can examine the heads for flatness, and check the gaskets for common failures, before ordering any parts.
msm15
Jan 18, 2011 09:54 PM
