Compression test numbers...
Old Jul 9, 2013 | 01:03 AM
Grease Monkey's Avatar
Default Compression test numbers...
I recently picked up a 03 disco that "needed a new engine." I was not bothered by the engine because I have a diesel that I'm going to be stepping in at some point. I figured I would at least see what is wrong with this 4.6 since I'm still saving up for the diesel swap. Anyways, all I was told was that the rover had overheated. I did a dry and dry test today on the engine and have super low numbers. Here's the results
Dry. Wet
1: 155 1: 200
2: 170. 2: 200
3: 100. 3.110
4: 110. 4: 120
5: 70. 5: 70
6: 65. 6: 70
7:80. 7: 70
8: 85. 8: 90
Any ideas? I was hoping maybe I could do head gaskets and call it but I don't think that's the case after seeing this. Thanks for any info! Cody
Old Jul 9, 2013 | 01:27 AM
An HG job would include a trip to machine shop, where a valve job is normally part of the price. $250 in my case. $118 for HG kit. With bad HGs, and warped heads, adding oil won't make much difference as gasket is not holding pressure to start with.
On the other hand, if you pull the heads, you can examine the heads for flatness, and check the gaskets for common failures, before ordering any parts.
Old Jul 9, 2013 | 07:58 AM
The general rule when looking at compression is there should be no more then a 10% difference between high and low cylinders. This engine is in trouble and head gaskets won't fix it.
Old Jul 9, 2013 | 09:26 AM
drowssap's Avatar
pull the heads you have nothing to lose but a few hours of your time
Old Jul 9, 2013 | 11:01 AM
antichrist's Avatar
Do a cylinder leak down test before opening the engine to see exactly where the issue is. Or at least where the most likely location is.
Old Jul 9, 2013 | 11:26 AM
- for others could you describe the leakdown test in detail?
Old Jul 9, 2013 | 01:20 PM
antichrist's Avatar
There are actually tons of videos on youtube.
There's nothing Land Rover specific about doing them.
Old Jul 9, 2013 | 02:36 PM
caymandrew's Avatar
This seemed pretty good:
Old Jul 10, 2013 | 12:34 AM
Thankful for the input guys. I don't have a leak down tester so I guess I'll either buy one or just go ahead and pull the heads to see what's going on.
Old Jul 10, 2013 | 12:41 AM
Flatness spec is 0.002 inch.
williamlynch339
Freelander
Oct 23, 2013 09:38 PM
msm15
Jan 18, 2011 09:54 PM
maxman
Jan 9, 2011 08:18 AM
btbaus
Jan 20, 2010 04:38 PM
afphinfan
Jan 1, 2008 05:58 PM
