Condenser Fans not turning on
Old Mar 17, 2010 | 09:16 PM
Are you sure it was the high beams and not the DRL's?
Old Mar 17, 2010 | 09:22 PM
ibyrover98's Avatar
7th Gear
It was a empty plug. Like if someone had pulled off the relay. I assumed that was my problem. I plug in a relay into (with everything off, no key or engine on) and the high beams came because the indicator on the dash show blue. Left it one and started the truck, turned on a/c but no fans. Fans do spin freely. The empty harness is black in color.
Old Mar 17, 2010 | 11:38 PM
ibyrover98's Avatar
7th Gear
After checking every freakin' relay I removed the front grille and check the voltages at the fans. Finding out I'm getting 12v when A/C on but no fan operation. Decided to tap the fan motor with my screw driver and it started to turn a little. Should have done that in the first place. Going on Ebay to look for fans. thanks for the help!
Tim P.
May 18, 2015 07:07 PM
tibyABv6
Jun 24, 2011 04:50 PM
jefsantiago
Oct 10, 2010 07:50 AM
MarvelVT
Jun 9, 2009 03:33 PM
eddyendo
Jun 1, 2008 04:41 PM
