confused on engine size
Old Oct 11, 2012 | 02:23 PM
Uganda's Avatar
Default confused on engine size
I am considering the purchase of a 2003 Discovery SE from a Japanese dealer. They list the engine size as 3900 cc. Everything I have read about this truck says this vehicle comes with a 4.6L V8. Shouldn't that mean the engine is 4600cc?
Old Oct 11, 2012 | 02:39 PM
br0keit's Avatar
Pretty sure its just a different crank that increases the displacement while everything else is the same, so a 2003 should have a 4.6L in it.
Old Oct 11, 2012 | 02:42 PM
D2 had two different engine capacities, "4" liter and 4.6" liter, same block, longer stoke for piston. Should say 4.0 or 4.6 in big casting on top of engine.
From shop manual:
Bore 94.00 mm (3.70 in)
Stroke:
4.0 litre 71.04 mm (2.80 in)
4.6 litre 81.92 mm (3.22 in)
Capacity:
4.0 litre 3950 cm3 (241 in3)
4.6 litre 4554 cm3 (278 in3)
Might want to look at that vehicles owners manual because they do use different size engines in Japan, I believe.
Old Oct 11, 2012 | 02:54 PM
Just saw that in the RAVE:
Maximum power - 4.0 litre:
⇒ Low compression ratio 132 kW (177 bhp) at 4750 rev/min
⇒ High compression ratio - UK/Japan/ROW 136 kW (182 bhp) at 4750 rev/min
⇒ High compression ratio - NAS 140 kW (187 bhp) at 4750 rev/min
Maximum power - 4.6 litre 162 kW (217 bhp) at 4750 rev/min
So it would appear that a 4.0 was for Japan, 5 hp less that NAS version.
Old Oct 11, 2012 | 02:56 PM
pinkytoe69's Avatar
Thats weird. JDM engines usually have a little more than we do.
Old Oct 11, 2012 | 03:07 PM
Uganda's Avatar
Well, who needs a crmmy 5 hp anyway....
Old Oct 11, 2012 | 03:12 PM
Uganda's Avatar
I meant to say thanks BTW, for the explanations. Good forum!
roverbob
Feb 21, 2012 07:24 PM
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
artcareer
Aug 13, 2007 04:24 PM
Elhoff
Jun 9, 2006 10:48 PM
