Confused - Oil level - quick question (with pics)
Old Mar 22, 2018 | 07:33 PM
TheKooksSociety's Avatar
Default Confused - Oil level - quick question (with pics)
Hey, I am very confused when checking my oil level... I changed the oil a month ago and put a new filter. I added around 6.5 quarts of new oil. When I check the level (cold engine) I get this looking at the side with the text (couple of inches above limit)
But I can also get this - looking at the side without the text (just at / above the limit)
Any ideas? Should i completely change the oil again? Or just remove some (is that even possible)? I have a coolant leak that I need to deal with - I have read here that it can end up in the oil; but the oil would be milky then, correct?
Thanks!
Old Mar 22, 2018 | 07:44 PM
Best4x4's Avatar
Dumb question, but are you removing the dipstick, wiping it down first & then re-inserting it, and pulling it out again to read it? That normally will remove the excess that is in the dipstick tube for a more accurate reading.
Old Mar 22, 2018 | 07:47 PM
Jeff Blake's Avatar
Is that 6.5 quarts including the oil you pre-filled in the filter?
Too much oil. Trust the dipstick... it' If I'm doing a change, and not replacing the filter, I put in about a gallon.
If I'm changing the filter too, I use maybe 6 quarts max, but I also have a big M1-301 filter.
You can take some oil out by unthreading the drain plug
Old Mar 22, 2018 | 08:48 PM
Yes, I clean wipe the stick before checking...
Damn, I really did not want to have to do this... I guess no choice.
Thanks!
Old Mar 22, 2018 | 08:50 PM
Jeff Blake's Avatar
There are worse things to have to fix. Good luck.
Old Mar 22, 2018 | 09:04 PM
Indeed.
I was planning on changing my thermostat, and coolant... hope to have time to do both!
Old Mar 22, 2018 | 09:10 PM
Best4x4's Avatar
If it's like any other LR it'll probably loose that little amount of oil over the next few weeks anyway marking it's territory lol
Old Mar 22, 2018 | 09:17 PM
Alex_M's Avatar
Mine sometimes shows higher on one side than the other. It's no big deal. Just go by whatever the lower side says.
Old Mar 22, 2018 | 09:21 PM
Jeff Blake's Avatar
Originally Posted by TheKooksSociety
Indeed.
That's the trap. I was going to do the same, and ended up rebuilding the whole engine, mostly out of curiosity.... and paranoia.
Old Mar 22, 2018 | 10:04 PM
DiscoCam's Avatar
Thanks!
Mine is the same. Every rover I've owned was like that. One side of the dipstick is always way over, the other side is accurate. A little over full is ok, just don't go way over. I wouldn't worry about it, just leave it until the next oil change.
