Connector for Transmission Cooler Sensor
Old May 12, 2020 | 07:06 AM
ahab's Avatar
Well, you have an 04, so it shouldn't have the harness bit. At least my Feb '04 manufacture doesn't. Either your trans cooler was replaced with a part from an 03 and the cooler sensor came with it, or your truck was early enough in the phase-out that it got a cooler sender set up without the requisite bits to use it. What you might consider is making a harness to connect the cooler sensor to the two black female spades that are dangling back at the transfer case. It seems to me that a lot of the later trucks didn't have a temp sensor in the t-case or the trans (to be clear, I haven't seen a lot of trucks either), but there is the light in the dash. With some controlled-environment testing and observation you might be able to figure out if this would be a beneficial retrofit.
DakotaTravler
Jun 28, 2024 08:05 PM
seaosrover
Apr 16, 2019 08:58 AM
AdrnlnRush
Feb 14, 2014 12:32 PM
kmyer74
May 29, 2011 10:20 AM
Rover789
Jun 1, 2009 06:30 AM
