Converting an SE7 to SE or HSE rear cargo area
Old Apr 17, 2021 | 03:17 PM
Bignacio's Avatar
Default Converting an SE7 to SE or HSE rear cargo area
Anyone removed the rear seats from an SE7 and convert to the HSE or SE rear cargo area. Is it a big hassle? I sure could use the extra room since I rarely have a need for the small jump seats in the back. Thanks in advance!
Old Apr 17, 2021 | 04:02 PM
zski128's Avatar
I did this not too long ago. If you care about having both storage bins in the back you will need to cap off and remove the rear AC if equipped. I had an SE parts truck that I swapped all the part with. See my build thread for pics and steps.
Old Apr 17, 2021 | 04:37 PM
Bignacio's Avatar
Thanks for the info. I'm going to insulate the roof when I pull down the headliner. I don mind removing everything and capping off the rear ac.
Old Apr 17, 2021 | 07:26 PM
XRAD's Avatar
I just took the seats out of my 01 SE7....MUCH more room, and less banging around.....
I did not install the bins. I do not have rear AC.
Old Apr 17, 2021 | 08:30 PM
Bignacio's Avatar
I want the bins. I'll start looking for them and all the parts I need. I'll block off the rear ac unit. I'll probably save weight also by removing the jump seats. Maybe I can find a parts truck that has a clean interior.
toofaroffroad
Sep 19, 2020 03:59 PM
d.a.r.y.l
Jun 21, 2016 09:47 PM
dragonhead
Jan 21, 2013 06:11 PM
ndxtreme
Nov 1, 2012 02:22 PM
scottma
Dec 26, 2008 10:49 AM
