Coolant ?
I have an 2004Disco 2 SEw/ 44K, I am looking to flush the coolant, and wanted to know if I need to buy the coolant from Land Rover, or can I buy it at PepBoys. Which kind of coolant do I need to buy. Ioccasionally smell coolant when I get out of the truck. Where should I start at, I don't see any leaks.. Thanx in advance for the help.. Frank
[IMG]local://upfiles/12130/728962A767CD4163A32FD900648FC159.jpg[/IMG]
Before you waste your money on the coolant find your leak first, you will need to drain it to fix the leak so why buy it twice?
If you are dong a complete flush and fill I recommend Peak Global Lifetime premixed, if you are topping off you must use DexCool.
Just make sure that you change it every two years no matter the miles.
ZMonet
06-24-2016 04:00 PM
aguison
11-18-2012 05:15 PM
CANAMDiscovery
04-24-2012 07:19 AM
