Coolant ?
Old Nov 14, 2008 | 02:28 PM
cruzin's Avatar
Default Coolant ?
I have an 2004Disco 2 SEw/ 44K, I am looking to flush the coolant, and wanted to know if I need to buy the coolant from Land Rover, or can I buy it at PepBoys. Which kind of coolant do I need to buy. Ioccasionally smell coolant when I get out of the truck. Where should I start at, I don't see any leaks.. Thanx in advance for the help.. Frank
[IMG]local://upfiles/12130/728962A767CD4163A32FD900648FC159.jpg[/IMG]
Old Nov 14, 2008 | 02:31 PM
Disco2Guy's Avatar
Default RE: Coolant ?
You should use DexCool, the pink stuff. Double check what you have in the res tank to be sure though. Get the pre-mixed stuff (Prestone I believe) and you should be good to go. Take the truck and have the coolant system pressure tested to find the leaks.
Old Nov 14, 2008 | 07:30 PM
Before you waste your money on the coolant find your leak first, you will need to drain it to fix the leak so why buy it twice?
If you are dong a complete flush and fill I recommend Peak Global Lifetime premixed, if you are topping off you must use DexCool.
Just make sure that you change it every two years no matter the miles.
ZMonet
Jun 24, 2016 04:00 PM
CANAMDiscovery
Apr 24, 2012 07:19 AM
G Reeves
Feb 21, 2012 02:39 PM
skeester
Dec 30, 2011 05:42 AM
