Coolant colours
Old Apr 10, 2013 | 10:07 AM
Darthpoet's Avatar
5th Gear
Default Coolant colours
Simple question, should you put green, blue or orange coolant in a Discovery series 2 model year 2002. Does it really matter, and if so, why?
Old Apr 10, 2013 | 10:14 AM
drowssap's Avatar
quick answer if it's orange it is probably Dexcol which doesn't not mix with anything else.
I say probably because I have seen some store brands that are orange and are not Dexcol.
Land Rover used Dexcol because it hade a long life span, but later there were problems found with it, the best thing you can do if you do have orange coolant is have it removed and replaced with standard antifreeze.
Old Apr 10, 2013 | 10:26 AM
ditto
The Dexcool when contaminated by air, water, other coolant, pixie dust, etc., can turn into a mud sludge that will also decompose things like radiator cap. Flush and go green 50/50 premix, only top up with same or a jug of distilled water. Flush and replace coolant like 3 years or less. 10 year coolant is part of the "big plan" to make used vehicles so expensive to maintain that people will buy new. And 10 year coolant shifts the repair bills from the lease holder to the final owner. And cash for clunkers took out our low priced supply of cars. Purchasers of prime posh pre-owned sheet metal can't get a break.
Attached Thumbnails Coolant colours-dex-cool-2.jpg   Coolant colours-dex-cool-3.jpg   Coolant colours-dex-cool-4.jpg
Old Apr 10, 2013 | 07:31 PM
As long as it is aluminum safe you can use whatever you want, I would stay away from the organic acid technology (OAT) coolants.
I prefer to buy it in the pre-mixed because it is idiot proof.
Old Apr 11, 2013 | 04:19 AM
FlyingZebra34's Avatar
Green. Green everything. Land Rover emblem is green which means green coolant. Green Rover. Green
Old Apr 11, 2013 | 07:49 PM
Darthpoet's Avatar
5th Gear
thanks, guys, I guess I'l stay green then!!!! lolol
Old Apr 11, 2013 | 11:30 PM
symaxwell's Avatar
Is there a write up on flushing the coolant. I just bought 2 gallons of Peak 50/50.
Old Apr 12, 2013 | 12:59 AM
Here's a GM TSB on how to flush Dexcool, just don't refill with same.
File Type: pdf
Old Apr 12, 2013 | 06:05 AM
drowssap's Avatar
there are drain plugs on the block, DO NOT TRY AND REMOVE THEM. skip that part.
Old Apr 12, 2013 | 08:29 AM
Amen - they will be so corroded you don't want to disturb them.
