Coolant Exhaust Gas Test Kits
Old Nov 3, 2011 | 11:37 AM
0304Disco's Avatar
Default Coolant Exhaust Gas Test Kits
I've been searching locally for the coolant test strips that so many have spoken about but can seem to find them at any of the autopart stores.
I did find one Napa who had the strips but had no instruction so it wouldn't have done me much good.
I've found this kit on Amazon and was wondering if anyone has used it or had a kit I could purchase on-line that was similar and less expensive.
http://www.amazon.com/UVIEW-560000-C...pr_product_top
Old Nov 3, 2011 | 11:48 AM
NAPA - see NAPA AUTO PARTS, some of the strips you see are for coolant freeze level and pH testing.
Old Nov 3, 2011 | 11:58 AM
0304Disco's Avatar
Looking for something cheaper. The strips would be great but I don't know if the strips that indicate PH condition would help me.
Old Nov 3, 2011 | 12:14 PM
drowssap's Avatar
The kit you found on amazon I have seen in action and works amazingly well, for $50.00 buy it and sell it when your done. The fuild is only $10 a bottle you rent it out like people do with the ABS amigos. If I had questions $50.00 would be cheap for piece of mind.
Old Nov 3, 2011 | 03:28 PM
So what is it you are wanting to test, the coolant level or exhaust leakage as in a chemical block testing kit?
Old Nov 3, 2011 | 11:37 PM
0304Disco's Avatar
Looking to test for exhaust leakage into coolant. I should have mentiones that.
Old Nov 4, 2011 | 04:42 AM
And do you have other symptoms of leak, like loss of coolant, coolant sweet smell, white smoke from exhaust, overheating, rushing water and gurgle under dash ? Plus, that kit will test other vehicles beside Rovers, don't know shelf life of an opened bottle of the chemicals...
Old Nov 4, 2011 | 05:45 AM
drowssap's Avatar
the strips you see at autoparts stores are to check the ph count of your antifreeze, unless they are marked otherwise. You are looking to check for a Combustion Leak Tester.
Old Nov 4, 2011 | 03:49 PM
Merlin390's Avatar
Napa p/n 7001006
knightmetro
May 27, 2014 01:23 PM
Yoops Racing
Feb 28, 2014 09:11 AM
TripleThreat
Feb 14, 2014 09:21 PM
Street Wolf
Jun 24, 2011 01:59 AM
