Coolant flying all over the place this morning!
Old Aug 8, 2013 | 03:34 PM
Soja4JC's Avatar
Question Coolant flying all over the place this morning!
I was parking at work this morning and suddenly billows of white smoke were coming from under the hood. I popped the hood to see coolant spewing in a stream from a crazy location. I checked and it was all antifreeze, no oil. I am inculding pics. Hopefully they can help. Can anyone look at these and tell me why coolant would stream from the seam?
Thanks!
Nathan
Attached Thumbnails Coolant flying all over the place this morning!-69283406.jpg   Coolant flying all over the place this morning!-gosmsphoto1375986382990.jpg   Coolant flying all over the place this morning!-gosmsphoto1375986562130.jpg
Old Aug 8, 2013 | 03:42 PM
Soja4JC's Avatar
Thanks to Bryan H for letting me know it was the throttle body heater plate. I'm thinking the gasket must have gone bad? I'll order one from AB and install it!
Old Aug 8, 2013 | 04:06 PM
kdscott100's Avatar
or simply get a copper pipe and join the two, which many in the Southern climates have done.
Old Aug 8, 2013 | 04:15 PM
Coyote's Avatar
If you replace the plate / gasket with a new one and do not bypass it, make sure you get the hose clamps on the nipples good and tight. There is not much of a barb on them, and I had one hose pop off on me.
Old Aug 8, 2013 | 05:08 PM
I by passed mine 10 years ago with a small piece of copper tubing, never had a leak since
By the way, Rover has never been able to fix that after 4 design changes, thats why I got rid of mine.
Old Aug 8, 2013 | 06:08 PM
NiteTrain's Avatar
I by-passed mine 5 years ago with some rubber tubing. I can take pics if you need to see it.
Old Aug 8, 2013 | 08:03 PM
Bypass it, and whilst in the store fetching double male hose fix fitting procure a container of spray carb cleaner and have at the nasty throttle body.....
Old Aug 8, 2013 | 10:08 PM
mln01's Avatar
Whilst?
Old Aug 8, 2013 | 10:15 PM
NickAdams's Avatar
Yep, whilst is a word. You can look it up.
I would not by-pass mine, because I live in northern Michigan where it might be 15 below zero Fahrenheit some mornings. I do not note from your post your location. As has been stated, in southern climes you are likely safe with the by-pass.
Old Aug 9, 2013 | 02:20 AM
Rover_Hokie's Avatar
Per the dictionary I reviewed, whilst is the Cheifly Brit form of "while', so is most fitting here chaps! And that is why Savannah Buzz is a Super Moderator my friend
