coolant hoses
Old Jan 23, 2015 | 11:36 AM
DustyLBottoms's Avatar
Originally Posted by dusty1
yep. I am planning; radiator -hose- water pump - hose - fabbed up ss octopus section. checked all the usual rover supply outlets then moved on to the generic supply houses. parts geek had the original listed, but responded with the new part number. thought some one might have back stock of old ones...... nope.oh, well. tis what tis
Dusty, as you know I've been trying to come up with a bullet-proof metal solution for the plastic in the cooling system. The upper T was easy, but unfortunately I haven't found an easy solution for that y-pipe yet.
Old Jan 23, 2015 | 12:07 PM
dusty1's Avatar
well there are options out there. I cant use a standard set, due to my set up....in line water pump, 2 sender sections (fore and aft), in line stat, in line thermostatic switch section....... the uk flea kits and places like DIRENZA LAND ROVER DISCOVERY 2 II 4.0 V8 98+ SILICONE ENGINE RADIATOR RAD HOSES HOSE KIT are a solution, other wise
Old Jan 23, 2015 | 12:26 PM
ZGPhoto's Avatar
^nice
Old Jan 23, 2015 | 12:30 PM
dusty1's Avatar
yes....if only it came in pink.
Old Jan 23, 2015 | 06:46 PM
zeroone's Avatar
I'm not trying to hijack your thread dusty, but is that little plastic "Y" an issue if replaced with the same thing? I'm not into making parts for this thing, just asking a question really.. I'm guessing the originals where made of metal?
Old Jan 23, 2015 | 07:14 PM
dusty1's Avatar
the original in my 00 and my last 2 d2s were just like the above section, except standard rubber not silicone. later this supplied section was changed to the plastic y inclusion. I hate those plastic pieces......they brittle and break.....a while back, I had to totally remove all hoses and the radiator just to find a chunk of the plastic t was stuck in my radiator. I no longer find them acceptable. but you can always replace them before they become an issue. prolly every couple to few years or so
Old Jan 23, 2015 | 07:45 PM
zeroone's Avatar
Oh ok. Thanks for clarifying that for me dusty!
Old Jan 27, 2015 | 02:27 PM
mln01's Avatar
Here's what we found when we replaced the plastic union in my friend's '04 Sunday afternoon.
Old Jan 27, 2015 | 06:08 PM
ZGPhoto's Avatar
^that's what mine looked like 3 weeks ago. Cracked while I was replacing the waterpump in the parking lot at -8 degrees.
Old Jan 27, 2015 | 06:40 PM
dusty1's Avatar
My upper t busted a couple of years ago. Replaced a radiator before I found the problem.
No more plastic for me.
