Coolant leak
Update on my oil leak: Its not coming from the front its coming from the back i believe because the back is covered in oil around the passenger side o2 sensor in the engine bay what could that be (its all over the sensor and the connector for it)?
Also i have a coolant leak now I'm assuming its coming from the throttle body??
Its leaking on the drivers side valve cover. I came out and the reservoir was empty. i took some pictures all help appreciated!
^^ what he said...while you wait for the parts you can just bypass it with some hose.
Since it says you're in the south, you could in theory keep it bypassed but I'm accepting no liability if you get a freak cold blast and your throttle body gets stuck open in the winter.
I'd just bypass it while you wait for parts then you wont leak coolant in the mean time.
Letting it leak on your engine will cause the truck to run awful. Make the Service Engine Soon light blink just like your turn signal. It gets the Crank sensor wet and causes it to read wrong.
As for that plug, I have no idea. Never noticed it before. If you dont have any lights on the dash it's probably there for some sorta option you dont have installed.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
aguison
Nov 18, 2012 05:15 PM
lipadj46
Jul 8, 2009 07:41 PM
