Coolant leak... Cracked sleeve?
Old Mar 26, 2010 | 06:17 PM
rewi9d's Avatar
Default Coolant leak... Cracked sleeve?
I have a pretty constant coolant leak. The engine was just replaced with a rebuilt one. The reservoir is half full every other day. I can't seem to find any major leaks, and it doesn't leave pools in my driveway. Oil and coolant are both clean.
Any ideas on what could be going on?
Old Mar 26, 2010 | 06:41 PM
Did you replace the head gaskets when you replaced the engine?
Old Mar 27, 2010 | 07:41 AM
rewi9d's Avatar
Yep. New headgasket. New waterpump.
Old Mar 27, 2010 | 07:44 AM
Did you use new head bolts? When cold starting do you get any white smoke, does your exhaust smell sweet?
Old Mar 27, 2010 | 07:53 AM
rewi9d's Avatar
I did notice white smoke the other day, but not every time. The exhaust doesnt smell like antifreeze at the moment. The engine was bought as a long block, preassembled. I had a shop swap it in.
Old Mar 27, 2010 | 09:08 AM
rewi9d's Avatar
I'm hoping there's another possibility, because its literally got like 1000 miles on the new engine.
Old Mar 27, 2010 | 09:55 AM
okdiscoguy's Avatar
What year are we dealing with here?
Old Mar 27, 2010 | 10:08 AM
Rovin4life's Avatar
add some dye and run it. then use a black light to determine any leaks might even be say a radiator or something else.
Old Mar 27, 2010 | 10:55 AM
rewi9d's Avatar
Its a 2004
Old Mar 27, 2010 | 02:50 PM
okdiscoguy's Avatar
Start by checking all of your hoses. The t-body heater plate is a common place to leak, and the dye suggested above is a good step too. Be mindful of the level, if it overheats, you are looking at another block.
Was this a used long block?
