Coolant Leak, then no Coolant Leak? Any Logical Explaination?
Old May 4, 2011 | 08:02 AM
Bundu's Avatar
Banned
PT sells the good one, not a POS one.
Old May 4, 2011 | 08:01 PM
2 hours labor charge for a 1 hour job?
Sounds about right.
It actually bills as a 1.1 hour job.
Old May 5, 2011 | 08:30 PM
sbadams17's Avatar
4th Gear
It wound up being about $150 for a pump that was in stock locally and about an hour to fix. Thanks for the guidance, all!
Old Jun 24, 2016 | 02:51 PM
Ed Whiston's Avatar
2002 Disco II, 122k.
I had this issue, it turned out to be a crack in the plastic 3-way joint between the heater hose and thermostat. When the engine got very hot, say 200F the crack would open up and spew out the coolant, but would then re-seal when the pressure went down, but the engine would overheat. I went 'round and 'round with this thing until finally I pulled the hoses off to check for splits and found this crack. When I tugged on it a little bit, it broke in two. My recommendation is to check hoses regularly and replace them at recommended intervals, which I think is about every 50K miles.
Old Jun 24, 2016 | 04:00 PM
Big Jim Swade's Avatar
I replaced my water pump about 2 years ago, it's a pretty simple job. Took longer to remove the old gasket material from the engine side of the water pump than anything else.
MurphyPeoples
Mar 11, 2015 06:01 PM
Thatdudeuno1
Mar 26, 2012 08:33 PM
blast20
Jul 17, 2010 04:10 AM
jeffmalone
Mar 13, 2010 09:23 PM
yukonridin23
17
Aug 8, 2009 02:06 PM
