runs then doesnt, then does
Old Mar 13, 2010 | 05:27 PM
jeffmalone's Avatar
Default runs then doesnt, then does
i recently purchased a 1996 land rover discovery, it has 203,000 miles on it. It starts and runs on ocassion it displays no lights on the dash, after it wont start. It will still crank over, so I took off a spark plug wire it did not produce spark will cranking over. the previous owner instaled a battery disconnect . when it wouldnt start he would disconnect the battery, reconnect it within a few minutes. it would run until shutoff. now the discovery will only start once in a blue moon. all help will be appreciated.
Old Mar 13, 2010 | 05:30 PM
NiteTrain's Avatar
have battery tested, check CPS (crank position sensor)
Old Mar 13, 2010 | 05:35 PM
Sounds like a bad crank sensor.
That is what controls spark.
The battery disconnect was just resetting it so it thought it was fixed, until next time.
but now it is bad enough that it cant be fooled.
Old Mar 13, 2010 | 08:57 PM
jeffmalone's Avatar
thanks i'll try the crank sensor. i'm going to try to find a place on this forum for the part, but does anyone know of a good place to get the part.
Old Mar 13, 2010 | 09:23 PM
NiteTrain's Avatar
http://www.roverparts.com/
Gray8188
Jul 14, 2012 08:33 PM
DiscoDad
Dec 5, 2010 04:58 PM
RedCliffsRover
Jan 27, 2010 12:23 PM
jhammerstrom
Mar 21, 2009 06:35 PM
specbiker
Aug 10, 2008 03:00 AM
