coolant leak top of valve cover..huh?
Old May 21, 2008 | 01:07 PM
geotrash's Avatar
Default RE: coolant leak top of valve cover..huh?
ORIGINAL: NiteTrain
I've worked on lots of different vehicles before (mostly fuel injected) and I have never seen this feature before. I just took a look at my E46 BMW to verify it does not have it. It seems to me in warm climates this feature would heat the intake air giving you a hotter, less dense charge thus less power. Think intercooler in reverse.
Induction icing is not the problem in FI engines that it was in carbureted engines because carbs relied on a venturi to mix the fuel and air proberly and multipoint fuel injectedengines do not. The pressure (and subsequent temperature) drop across the venturi was often enough to condense the water out of the air, causing ice to accumulate. Carbureted piston aircraft engines have a carb heat **** to prevent the problem.
While there is a pressure drop across a throttle body, it is nowhere near the drop that occurs with a carb venturi, so a heater is less likely to be needed to prevent ice from forming. You are correct that heated intake air would result in a considerably less dense charge and a richer mixture. This is compensated for by the sensors in the system.
Remembering that the Land Rover is built to endure climate extremes, the TBheatermaybe missed under extreme circumstances, but I've never heard of anyone running into problems by bypassing it.
Dave
Retroman1969
Apr 6, 2014 09:05 PM
LeakyDisco
Feb 26, 2012 12:33 PM
montana968
Apr 30, 2011 06:18 AM
OJs DNA
May 6, 2008 10:18 PM
