Coolant Leak from under expansion tank
Old Feb 5, 2011 | 03:44 PM
lord.of.the.idiots's Avatar
Default Coolant Leak from under expansion tank
The other day I noticed coolant on my garage floor after my wife left for work in my 2003 Disco SE with 80000 miles on it. The coolant on the floor looked like it had been dripping all night.
I topped it off when she got home (not running hot). This morning I noticed that the leak was 2x as bad, so I topped it off and let it run for a little bit. After a few minutes I noticed coolant coming from the bottom of the expansion tank.
Any suggestions?
Old Feb 5, 2011 | 04:35 PM
FightOnUSC79's Avatar
Any suggestions?
I had a similar issue with my Audi and come to find out the tank itself had split. No explanation as to why, but replace it an never had another problem with it.
Old Feb 5, 2011 | 04:36 PM
Replace the tank!
Old Feb 5, 2011 | 04:55 PM
yloDiscoII's Avatar
^ What they said, then replace the hose clamps to the worm style clamps, those factory clamps get worn out and there's no way to tighten them.
Old Feb 5, 2011 | 05:01 PM
bosshogt's Avatar
If you have not already do so. The tank realeases up. Gently rock it back and forth and it will come up. Then you can see for sure if you have a crack on the bottom. 2x on the worm drive hose clamps. I bought a 10 pack of the tiny ones and have put one on every hose I can find in my 2003. Even after I did the throttle body fix I was getting a drip from a hose...it was the old crappy style hose clamp
Old Feb 5, 2011 | 05:03 PM
Those clamps don't wear out, and besides, there are none under the bottle.
If nothing else, carefully pick up the bottle, without breaking either of the 2 black plastic hoses and see what you find.
Old Feb 5, 2011 | 07:26 PM
Thanks for all of the great advice. After I posted this, I search more post and found the idea about putting another clamp on it. So I went out to my garage and cleaned the bottom of the tank off and I could not find a hole in it, I then tugged on the nipple and it didn't budge (I feel like a pervert for saying that). There was fuild in the tank over the nipple and I could not find a leak around it. So I bought a small clamp and put it right above the old clamp and it seems to be working ok. I let it run with the heater on for 10 minutes before taking it for a long drive.
I did not mention that we have had record setting cold weather here this week and this all started after my wife got called into the hospital one night this week in the middle of the night. Not sure if that (the cold weather) had anything to do with it or not.
I plan on using this as an introduction with the local independent euro shop here in town this week. I think I am going to have him make sure there is not a hole in the tank and then see about replacing the Expansion Tank To Throttle Hose (that is the one that was loose).
Thoughts - Suggestions?
Old Feb 7, 2011 | 04:29 PM
yloDiscoII's Avatar
I've had 2 separate "dissapearing coolant" issues due to those clamps losing their tension, don't tell me they don't wear out...
aguison
Nov 16, 2012 09:29 AM
jfry75
Sep 12, 2009 02:40 PM
brooksa
Jan 17, 2009 03:09 PM
twalter87
Sep 9, 2007 08:47 AM
