Coolant Leak. Valley Pan Gasket?
Hi guys. I noticed crusted coolant dripping down the bell housing and pooled up in spots below the valve cover gaskets. I did the head gaskets at about 50k with ARP head studs and didn't skimp on gaskets, lower temp thermostat, etc. From what I've read it sounds like a good possibility that it's the valley pan. I haven't had a chance to confirm with a pressure test yet. Are there any other seals other than valley pan gaskets and valve cover gaskets that I would need in the case that (fingers crossed) it is in fact the valley pan? I loose maybe a quarter of a cup of coolant every three weeks or so. It's probably been going on for a couple of months, but just noticed the pooling in the last week. Thanks for any advice.
That was totally the issue! I replaced the seal and soaked up the coolant underneath the pipe. No more leaking. Thanks for the tip! Much easier repair than a second round of head gaskets.
Phatrowles
01-09-2014 10:36 AM
