Coolant Leak. Valley Pan Gasket?
Old Dec 6, 2017 | 01:31 AM
Echoman's Avatar
Default Coolant Leak. Valley Pan Gasket?
Hi guys. I noticed crusted coolant dripping down the bell housing and pooled up in spots below the valve cover gaskets. I did the head gaskets at about 50k with ARP head studs and didn't skimp on gaskets, lower temp thermostat, etc. From what I've read it sounds like a good possibility that it's the valley pan. I haven't had a chance to confirm with a pressure test yet. Are there any other seals other than valley pan gaskets and valve cover gaskets that I would need in the case that (fingers crossed) it is in fact the valley pan? I loose maybe a quarter of a cup of coolant every three weeks or so. It's probably been going on for a couple of months, but just noticed the pooling in the last week. Thanks for any advice.
Old Dec 6, 2017 | 10:54 AM
Sixpack577's Avatar
Check the coolant pipe going into the front of the lower intake manifold, it has an o-ring in it.
Apparently, the coolant can run over the top of the valley pan gasket, and down the back of the block.
Old Dec 6, 2017 | 06:34 PM
Extinct's Avatar
True dat. Also check the coolant temp sensor and the hose connection in the front of the lower intake.
Old Dec 8, 2017 | 07:56 PM
Echoman's Avatar
That was totally the issue! I replaced the seal and soaked up the coolant underneath the pipe. No more leaking. Thanks for the tip! Much easier repair than a second round of head gaskets.
Old Dec 9, 2017 | 11:17 AM
Sixpack577's Avatar
Great!
Glad it was a simple fix
Phatrowles
Jan 9, 2014 10:36 AM
KindaGuitarded
Jan 4, 2013 01:21 PM
jpmiller
Sep 26, 2012 06:32 AM
duggerc
May 8, 2011 08:54 AM
JimScream
Jan 6, 2009 02:01 PM
