coolant level
Well i work 5 mins. from my house. When i get home and check my coolant level it is at the top, right up to the cap. It looks like its under a lot of pressure. And some times leaks from back of motor.I changed my thermostat and it still does it. But when i drive it for about an hour or so and check its fine..??? Is this normal???
Thanks...
Ryan
Thanks...
Ryan
Its a rover, True if it isn't boiling over dont worry about it. And for the cooling system to work properly it has to be under pressure. One thing to try, is if it keeps raising in the expansion bottle is to bleed the cooling system, you might have a air pocket in the lines.
