coolant level
Old Sep 10, 2008 | 03:00 PM
ryanljcom's Avatar
Default coolant level
Well i work 5 mins. from my house. When i get home and check my coolant level it is at the top, right up to the cap. It looks like its under a lot of pressure. And some times leaks from back of motor.I changed my thermostat and it still does it. But when i drive it for about an hour or so and check its fine..??? Is this normal???
Thanks...
Ryan
Old Sep 10, 2008 | 03:39 PM
Default RE: coolant level
As long as you are not boiling over and the temp is normal, dont worry about it. You should never open the coolant resevoir when hot anyways.
Old Sep 10, 2008 | 05:47 PM
Mine always stays right at the cap line.
A little drop is OK, if it gets any worse then you may need to look into it a little.
Old Sep 11, 2008 | 08:27 AM
sailorcolin's Avatar
Its a rover, True if it isn't boiling over dont worry about it. And for the cooling system to work properly it has to be under pressure. One thing to try, is if it keeps raising in the expansion bottle is to bleed the cooling system, you might have a air pocket in the lines.
Old Sep 11, 2008 | 04:52 PM
ryanljcom's Avatar
Yeah thanks.
Alot of air was in the system........
Old Sep 11, 2008 | 05:16 PM
Landzu's Avatar
When cold you should be able to see a plus sign (+)in the jug the antifreeze
should be at this not much higher when Cold.
Old Sep 18, 2008 | 11:15 AM
targotsi's Avatar
Sorry to break in, but I am curious as to what you did to bleed out the air. I think I may have a similar issue and would like to give this a try. Thank you.
Old Sep 18, 2008 | 11:26 AM
Do you have a DI or a DII? The bleed procidure is different for each. Alittle more to it on a DII, but not much.
Old Sep 18, 2008 | 11:41 AM
targotsi's Avatar
It is a 1995 3.9L Discovery I.
Old Sep 18, 2008 | 11:42 AM
If your engine is leaking coolant from the back of the block, you better go see your mechanic and have it pressure tested, ASAP, may be a head gasket.
