Coolant line for Manifold to Expansion tanks
Old Aug 17, 2021 | 08:16 PM
Richard Gallant's Avatar
Default Coolant line for Manifold to Expansion tanks
I need to replace that line, leaks at the manifold. Although I searched no joy on size, can anyone recommend size and type of rubber hose. ?
Mandatory Pictures -dye kit and cheap UV flashlight well worth the $35.00
Old Aug 17, 2021 | 09:38 PM
Extinct's Avatar
5/16 Automatic transmission cooler hose.
Old Aug 17, 2021 | 11:00 PM
@Extinct Thanks for both responses !
Old Aug 18, 2021 | 11:03 PM
Well found what appears to be the issue, the hose that attaches to the lower intake manifold was shot. Went to put a screwdriver in the hose clamp and the entire hose spun freely, zero clamping force. Now I just need a pressure tester.
Old Aug 19, 2021 | 04:31 AM
Extinct's Avatar
I know Advance rents a good set.
Old Aug 19, 2021 | 09:45 AM
@extinct we have literally have one choice, CDN Tire for auto tool rentals, the local store is useless as they never have anything. If the one 20 minutes away does not have one I will put her back together and hope for the best. Worse case I have to take all apart again.
Old Aug 19, 2021 | 03:56 PM
Extinct's Avatar
Well I suppose you could make your own with an air compressor, compressor fitting and tee fitting in the 5/16" hose, just don't put too much air pressure on it.
Old Aug 19, 2021 | 04:52 PM
I got a tester just need to figure out how adapt it, stand by for pictures. But I am thinking a bunch of duct tape
Old Aug 19, 2021 | 06:29 PM
Brandon318's Avatar
I have a dumb question - why aren't you just buying the actual hose rather than finding a generic replacement? Just curious, not judging or anything. I don't think they're NLA.
Old Aug 19, 2021 | 07:41 PM
Best4x4's Avatar
That plastic hard line gets brittle and just snaps when you least expect it. When I replace it with the 5/16 hose I slide a spark plug wire boot protector over the hose where it's exposed to the heat from the exhaust manifold.
