Coolant loss
Old Jan 8, 2009 | 12:27 PM
jasmine's Avatar
Default Coolant loss
Got a 2001 LR Discovery II SE right before Christmas. Previous owner informed me that it looses anti-freeze quite quickly. He keeps some in the truck to fill the resevoir, I've been doing the same but would like to just fix the issue. Any guesses as to why it drains so quickly? I'm hoping its just a hose. Thank you-
Old Jan 8, 2009 | 01:01 PM
salve7's Avatar
Default RE: Coolant loss
Do you see antifreeze dripping from underneath when you park?
Old Jan 8, 2009 | 01:22 PM
tomfraser's Avatar
note how much coolant you have
put pizza boxes or newspaper under the car and run it till it's warm
then shut it off and let it sit for an hour
if you don't see anything on the ground and coolant is missing then your engine needs work in a couple possible areas (big expensive fixes)
if there is coolant on the ground then find out where it is coming from
Old Jan 8, 2009 | 02:17 PM
Better yet, based on your question, and don't take this personally, but you need to keep it full and go to a shop so they can perform a coolant pressure test, do it ASAP cause Rover engine are real expensive to replace.
Get back to us with what they find and their estimate.
By the way, how much did you pay for this truck?
kman3786
May 5, 2009 07:56 PM
akbarkhan
Mar 7, 2009 12:24 AM
riden686
May 5, 2008 02:29 PM
ontheroadagain
Mar 27, 2008 08:10 PM
focusontheworld
Dec 1, 2007 11:30 PM
