Coolant opinions
Old Jun 26, 2009 | 11:12 AM
discoboy's Avatar
Default Coolant opinions
I am considering replacing my thermostat and flushing the cooling system and refilling with G05, does anyone think using G05 will be a bad idea? I am not a big fan of Dexcool. 2003 D2 with 68k, no cooling issues, just want to do preventative maintenance.
Old Jun 26, 2009 | 11:47 AM
A word to the wise, don't mess with what works based on your concerns. Yes Dexcool and be a problem if you don't change it every 2 years, but it is what works and is the only one recommended.
Old Jun 26, 2009 | 12:27 PM
okdiscoguy's Avatar
Dexcool is only bad if you have a leak. It is fine in a closed, sealed system. It is corrosive as heck when heated and put to atmosphere, but like Mike said, keep with what works.
If you want to do anything, add a bottle of Purple Ice or Water wetter when you change your fluid. Helps keep the truck cooler and keeps everything lubed inside.
Old Jun 26, 2009 | 03:31 PM
As long as it is aluminum safe you are fine, I prefer Peak Global Lifetime coolant.
I used to sell bulk coolant and DexCool is gunk, but it is enviromentaly "safe"
Do a complete flush with distilled water and then switch to whatever you want as long as it is aluminum safe.
Old Jun 26, 2009 | 05:32 PM
discoboy's Avatar
As always, thanks for the replies, a lot to think about..
SpeedE55
Sep 17, 2006 12:03 PM
Freelander1981
Freelander
Mar 14, 2006 04:27 PM
disco12
Feb 1, 2006 02:18 AM
Meyer
May 24, 2005 01:32 AM
