Coolant pump on a 2001 DII - Difficult?
Old Jan 4, 2010 | 08:03 PM
Originally Posted by gundog
Thanks Lipad. One last question. How do I find out if my Disco has ACE or active cornering enhancment? I see that this makes a difference in what belt to get.
Open your hood, find the power steering reservoir, does it have 2 caps or 1?
2=ACE
1=no ACE
Old Jan 8, 2010 | 08:29 PM
gundog's Avatar
Any thoughts on how to get the old coolant pump gasket off? Tried a plastic scraper but that bugger is on there good.
Old Jan 8, 2010 | 08:54 PM
lipadj46's Avatar
Plastic will not touch that gasket, razor blade and brake cleaner just be careful because it is aluminum and you can damage it easily if you scrape too deep. After you are done you can use some fine sandpaper to clean it up
Old Jan 8, 2010 | 10:01 PM
Baylink's Avatar
Indeed, as I note in my other thread, we picked up the sort of scraper that uses single-edged razor blades. But keep it flat against the face, and remember it's harder than the block.
It's a rough job -- it took us longer than any other single part of the job.
Disco Den
Apr 9, 2010 04:03 PM
dieselgeek
Jan 18, 2009 09:30 PM
Tara
Aug 23, 2007 04:17 PM
marcolanza
May 21, 2006 04:01 PM
djb
Freelander
Apr 9, 2006 03:01 PM
