Coolant question
Old Dec 9, 2010 | 10:37 AM
WindrockRover's Avatar
Default Coolant question
Last weekend, I noticed the waterfall sound behind my dash. Disco Mike walked me through the process and Monday evening I bled it and that went fine, and the sound went away. However, since Monday evening, my coolant level in the resevoir has dropped about an inch.
I haven't noticed a drop on the ground, and I checked my oil and no irregularities there either. It hasn't even hinted at running hot and my heat is working great, but I must have a small leak somewhere.
Any key spots that I should look at? It's obviously a very small leak, but I'd like to take care of it before it gets worse.
Last night I did read a thread about tightening the two v/c bolts because they tend to leak oil from there. Mine wasn't showing any oil leak, but I went ahead and tightened them anyway, as they were a little loose. Is there any way that I could have been loosing a little coolant from there as well?
Old Dec 9, 2010 | 02:18 PM
sloppyjoe's Avatar
throttle body heater gasket gone bad? or the other thing is once you burped the system and got the air out it allowed the coolant to disperse in the system and your fluid level evened out in the system.
Old Dec 9, 2010 | 02:55 PM
Don't see any evidence of the throttle body gasket being bad, so maybe it did even out. I'll top it off tonight and see if the level holds.
I also wondered about evaporation from the overflow hose.
Old Dec 12, 2010 | 12:29 PM
momentum59's Avatar
I'm having the same problem, i keep having to burp and bleed the system but no visible leaks after a full rebuild! I am at a loss of what to do next.
Old Dec 13, 2010 | 08:46 AM
oysterhead's Avatar
Pressure test is simple.
ZMonet
Jun 24, 2016 04:00 PM
CANAMDiscovery
Apr 24, 2012 07:19 AM
G Reeves
Feb 21, 2012 02:39 PM
skeester
Dec 30, 2011 05:42 AM
