Coolant Running 215-228 according to OBDII. Problem?
Old Aug 21, 2023 | 11:58 PM
  #21
V50-M66's Avatar
Originally Posted by arains44
Just for the benefit of the community, modern Dexcool DOES NOT turn into sludge and destroy your cooling system if/when exposed to air like the original Dexcool. It’s been reformulated since then. I researched it quite closely when I bought my D2 with Orange Dexcool coolant in it.
Unless your truck somehow still has the original coolant, running new Orange Dexcool stuff won’t have the disastrous effects you’ll read about if you Google Dexcool.
Maybe that's the case, but I've had far too many bad experiences with it and see no reason to run it over generic green stuff
Old Aug 22, 2023 | 03:56 PM
  #22
Discorama's Avatar
Be careful when replacing red by green coolant. Do some research before you do that. I am using genuine LR coolant, which is not that more expensive ($30 per gallon at FCPEuro, you need two containers for a dry refill).
Old Sep 26, 2023 | 02:09 PM
  #23
JettsRover's Avatar
Quick update: Discovered the engine temp went up (and up and up) when the AC was turned on. AC was producing air in-cabin of around 70f (read ideal temp is 45f). Got under the hood with an infrared thermometer and found several issues. AC compressor was running at 240 degrees. AC condenser had a big "hot spot" middle right. Had the AC system evacuated. Recharged it myself. No change. Still hot. Pulled the compressor and measured the oil. 2 ounces. Decided to replace everything. Pulled the condenser, dryer, fan motor and expansion valve (fan motor is backordered). Bought an AC flush gun kit an flushed the lines once all the components were removed. Starting off with 6 ounces of PAG 46 in the compressor. Now I just need to find the hours to put it all back together.
Old Sep 26, 2023 | 03:05 PM
  #24
Extinct's Avatar
Did you pull the dash to get the expansion valve out?
arains44
Jul 24, 2022 01:03 PM
rjlsierra
May 7, 2018 07:22 PM
CaptainAaron
May 8, 2017 03:32 PM
jwigum
Oct 17, 2015 06:47 PM
russburcham
Jul 13, 2013 07:49 PM
