Coolant System Bleed
Old Aug 7, 2013 | 12:59 AM
  #51
Water pump impeller is not aluminum. Head gaskets are multi-layer, with one layer being steel. Valley pan gasket is steel. So there is already ferros metal in contact with the coolant.
Old Aug 30, 2013 | 03:58 PM
  #52
coors's Avatar
Shout Out to ScreamingLife & primussucks.
I stripped the threads on the coolant bleed tee and didn't want to spend $100+ shipping on the entire hose assembly so, w/ the help of ScreamingLife and Primussucks I constructed this little beauty. I'm not thriled w/ the screw set-up, but at 9:00pm on a Thursday night, needing the truck back and running by morning, I made do. Plan is to switch the 1/4" brass screw out to something similar to the water line valve, to keep things clean while bleeding.
Stripped Threads, why the Fu%$ is this made of plastic? Horrible design.
Home Brew Bleed Tee:
Old Aug 30, 2013 | 04:08 PM
  #53
dr. mordo's Avatar
Why use two clamps on every hose?
Old Aug 30, 2013 | 04:38 PM
  #54
coors's Avatar
The galvanized pipe nipples are not concaved at the ends. See the ends on the black plastic tee? Notice how the rubber hose could slip over it easily, but not slip off easily? Adding two bands assures the hose stays in place and not slip off the home brew tee's nipple.
Old Aug 30, 2013 | 05:09 PM
  #55
dusty1's Avatar
this works great. i can see the bubbles.
Old Aug 30, 2013 | 07:08 PM
  #56
dr. mordo's Avatar
Ok, thanks.
Old Aug 30, 2013 | 08:58 PM
  #57
dusty1's Avatar
Ok, thanks.
Look at my pic. I just made sure that the union was over threads.teflon and One clamp... No problem. I happen to have a plumbing pipe threader, but u could just get short nipples.
But dual clamps are good insurance
Old Aug 31, 2013 | 06:16 AM
  #58
primussucks's Avatar
Originally Posted by Rover_Hokie
Is there any problem with the iron plumbing T and the coolant in regard to coolant moving through the iron? Any negative affect on the coolant?
Coolant has anti-corrosive properties, so it should protect the metal anyway
Old Aug 31, 2013 | 06:17 AM
  #59
Looks good! Keep an eye for drips, I had to go back after and place some right stuff around the threads. After that. Works like a champ!
Old Aug 31, 2013 | 08:15 AM
  #60
coors's Avatar
I read your post thoroughly before constructing, I added high temp pipe dope to the threads.
