Cooling System
Old May 15, 2019 | 01:43 PM
  #151
jastutte's Avatar
Originally Posted by Mstudt
I have it mounted with the spring/copper heat sensing element facing towards the engine so it's seeing the coolant flow from the engine. I'm pretty certain that's the correct direction, and my orientation of the stat has the jiggle valve at 12 o'clock.
Mike
doesn't the aftermarket housing have a directional flow arrow on it?
Old May 15, 2019 | 02:00 PM
  #152
Mstudt's Avatar
I did not see an arrow on the Meziere housing. Based on some quick research the orientation of the housing doesn't matter since it's 1-1/4" on both ends.
Mike
Old May 15, 2019 | 03:20 PM
  #153
Best4x4's Avatar
Yep direction marks on that housing would be pointless since the inlet/outlet are the same size.
Old May 15, 2019 | 08:47 PM
  #154
jastutte's Avatar
Mike
well, shows what i know.
Old May 16, 2019 | 09:00 AM
  #155
Mstudt's Avatar
I was able to get some work done last night on this. Picked up an 1/8" drill bit, drill 1 hole at 6 o'clock, and installed the new stat. Then something strange happened, the Rover didn't overheat.
I let it run for about 20 minutes while I checked temps all around with the IR scanner, and everything seemed fine. The hottest temp I saw on the computer was 206, and within 30-45 seconds after seeing that the temp dropped to 186. This was the norm for just about the entire time. The recent issue with the inline stat was all because of not drilling an 1/8" hole at 6 o'clock.
For now everything looks to be in good shape. Thank you to everyone who's help me out on this very long process.
Mike
Old May 16, 2019 | 09:27 AM
  #156
CollieRover's Avatar
That's awesome, after all the time and energy you've spent you deserve to be on the road.
Old May 16, 2019 | 09:30 AM
  #157
Mstudt's Avatar
Feels good to be able to put this behind me.
I'm not keen on the look of the inline stat, but man does it make changing them super easy.
Mike
Old May 16, 2019 | 10:46 AM
  #158
Mike
I had the same issue with a couple thermostats, and it was eye opening to see how cool it can run with no thermostat improving the flow of the coolant. When I do hoses again, I am going to switch, and maybe try to figure out a way to make it attractive, as I watch too much Motortrend channel and derive a lot of inspiration from the technicians. Frankly, I consider them artists, and what better form of art than a car?
Old May 16, 2019 | 10:53 AM
  #159
Best4x4's Avatar
I think the inline thermostat can be placed in the OEM spot. You’ve gotta replace that hose anyways with an inline setup. Then up top simply install a 90 1.25 vs the T 1.25. Don’t see anything wrong with that setup. It would be nice to have a bleeder on the 90, but it could be placed in the same spot I installed my pyrex glass 1.25 tube to monitor the coolant flow, condition and bubbles. Then when you needed to bleed it simply remove the hose from the shroud (how it’s held into place OEM) raise it & bleed from there.
Old May 16, 2019 | 01:48 PM
  #160
Mstudt's Avatar
I may change it up at some point, but think I'll leave it be for a little while.
Mike
