Coscast block FREE local pick up only (SF Bay Area)
Old Feb 26, 2025 | 10:05 PM
Tony Luna's Avatar
Default Coscast block FREE local pick up only (SF Bay Area)
You read that right - free. First to come to pick it up can have it. I'm in San Mateo.
Full disclosure. I picked this up about 6 or 7 years ago (link below). First build went well, but within a year I had a head gasket go - right between cyl 4 and 6 toward intake manifold. Building it a second time (because just replacing a head gasket wasn't good enough), I pulled the center threads when torqueing the heads down (using standard length ARP studs). I Heli-coiled the center holes and used longer studs from TWS all around. Finished new build. Had another un related failure almost a year later and decided to go big and send everything to TWS for a proper build. TWS put new sleeves in and while installing Heli-coils in the head stud holes determined that the metal was soft - failed pull test for the first Heli-coil install. TWS was nice enough to send me the Costcast block back and prepare another for the build I have now - which is AWESOME!!!
So there you have it, Costcast block with new sleeves and a partially pulled Heli-coil. I was going to make a table out of it, but now I just want it gone. If someone wants it and can pick it up its yours's, if not I'll scrap it.
https://landroverforums.com/forum/di...k-74118/page2/
KingKoopa
Dec 15, 2016 11:12 AM
bockscaracer
Nov 15, 2015 05:01 PM
yay4me.disco
Apr 20, 2014 08:55 PM
glassman66
Jul 17, 2012 08:31 AM
JBEGIN
Jun 27, 2009 12:38 PM
